Subwoofer wire
yea but i picked up 10foot of 12 today lol well ****
But i had it hooked up at 500 @ 4 to a kenwood and it was bangin a lil hard for me lol. So i may just run it 350 @ 4, these JBL power subs are LOUD. But im sure the single cab im in adds to the effect >.> lol
Just out of curiosity how many amps is my aq1200q at around 1200 watts putting out? I have 12 gauge wire for my 2 sa-12's atm seems to be working fine although i do have 12 on each sub and then parallel lines for each to get them to 1 ohm.
The current is split between the two wires when running parallel. So you use the equation above, but halve it for each run... If you combine at the sub and have only one run to the amp, then all of the current is on one wire.
if it's that short, then 12 AWG could be fine. note that 12 AWG is only rated for 20-25A. so you're on the edge.
distance is an important factor.
i'd use 10AWG anyway.
I hate this kind of google happy, egg-headed crap. Give me a break, dude. You ever see the coil wires on a sub?
10awg for 700w. Ok, bro. My 95Z 18 has 8awg leads. Does that mean I can only give it 1k?
700W at 1 ohm is 26 A. you want 10AWG wire.
P = I^2 * R
I = SQRT(700/1)
I = 26.45 A
note that 700W at 4 ohms is only 13.2 A
Although good in theory, strictly adhering to this method isn't correct in practice. When will that wire ever see a full 26A? Playing a 0dB sine wave at full volume. Aka probably never. Playing music 14ga wire is likely to be more than enough for that setup.
JoshC
The Taco MASTA
JoshC
Houston, tx
ultimate157
