Subwoofer Repair
whitem1ke88
.. BUILD IN PROGRESS ..
Well, not sure if this is the correct forum, I looked for 10 mins and figured this was the most appropriate. Sorry in advance if it's not.
The problem is with an Infinity Perfect 12" DVQ D4. The surround has literally separated from the cone. No damage, nothing like that. Just, the surround flaps around because it's completely separated on the inside, from the cone.
My question, is what kind of adhesive do I use to reglue this? I bought some off of some website that worked until I turned the radio on. You all I consider professionals and I hope you've beaten this situation before! Thanks!
-Mike
if you need glue. go to a hobby store and buy some CA glue... get the rubberized if they have it, but the clear will work to....it looks just like very thick superglue...
or , i bought some gorilla glue at walmart that looks just like clear super glue....it works great to.....
What's CA glue? And, you've used these before and they work right? I've tried so many diff things and nothing holds..
whitem1ke88
whitem1ke88
Broward, FL
ampjunkielikeme
