Subwoofer limits
Ok figured it out. I had a bad wire on my meter. So I got it tuned with a 0db tone but playing music there is definitely not enough bass. Some songs are loud and others aren't. What db level tones can I use safely?
You could use -15 as long as there's no distortion. I'd stick with -5 though.
It means you're reaching the limits of your amps output
I've seen exactly what you're talking about on almost all class d amps I've scoped, the class ab I scoped turned into a stepped sine wave which I consider soft clipped
I have an r500x1D and I'm only able to cleanly get about 450w rms anything above that it's fuzzy. Would a higher battery voltage or agm battery solve the fuzziness? I got a certificate that says 634w rms tested/certified.
DAMONMCHALE
DAMONMCHALE
Longmont, Colorado
DAMONMCHALE
