Subwoofer help
From what I understand that's the shallow mount series? Room isn't a problem, it's going in a extended console. The only limit is the bank. I'd like to keep it under 200, the lower the better
Any ideas on a good sub to run off the sound stream TA1.600D?It's going in a '86 Chevy c10 single cab.
Id run an SQ HDS210 (DVC2) in approx 1.4- 1.6 cu ft @ approx.32-34 htz should sound really nice,and do the big 3 for your electrical at bare min.Should do pretty nice for the money.
I would also like to make a suggestion as to place an American Bass VFL 26801 D amp on that sub and get a DVC 2 ohm. Great amp for such a small foot print. I installed this amp in a neighbors xcab chevy(04) on a pair of AB XFL DVC4 10s @ 1.6cu ft ea @ 34 htz ea and sounds amazing with the big three and stock alt(140amp) with an Orileys Super Start AGM battery.He is also running the VFL 150.4 on his Mids and highs (infinity Perfect 6.5 mids and CDT tweets
sorry guys, internet went down for a bit. The console is going to run from the dash to the back of the cab. and the volume should be around 2 cubes. I havent built the console yet so this is just a rough estimate. Thanks for the help!
ShinyC10
ShinyC10
Houston, Tx
treesive
