subwoofer depth
kdeyo
I'm driving a 2000 Silverado, using JL Audio Vantage subwoofer boxes for under the rear bench seat. I had two Sony Xplod 12"s in them, but just got two Hollywood Excursion 12"s from a friend of mine. Only problem is, when they are screwed down into the box the end of the magnent is right up against the top wall of the box (it's a down-fire box). Is this a problem? Will it make it sound like junk, or maybe hurt the subwoofer? I havent hooked it up yet b/c I didnt know what would happen. Just lookin for some help to see if they would work or not. Thanks
they need at least an inch or rearward clearance... if you do not give them it, a major sourse of cooling is blocked, which will drastically decrease the thermal power handling of your subs... basically... tehy will fry..
the cooling system (big hole in the magnet on the bottom) is going to need at least a tad bit of space behind the magnet so that it can breath... if its right up against it, it could overheat and burn your coils out....
Originally posted by mattj the cooling system (big hole in the magnet on the bottom) is going to need at least a tad bit of space behind the magnet so that it can breath... if its right up against it, it could overheat and burn your coils out....
too slow my man... too slow...
i was contemplating doing a response to that .. but i got lazy...
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Originally posted by Jmac And even if he was quicker than you, you could always delete his post //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
We cant delete individual posts...
- Steve
Originally posted by ss3079 We cant delete individual posts...
- Steve
OWNED
OWNED
however, I found a bit of a loophole
want to see it?
kdeyo
kdeyo
Florida
mattj
