okay i'll replace the 6mm thickness wire which used for the grund cabales with a 16mm thickness one to be as size as the power cable
or do you recommend to add another ground (16mm) to the current one (6mm) to be total (22mm), would there any problem if the power / ground cables are not same size ??
according to the gain setting, are you sure about adjusting the gain knob completely off ?
amp rated 1k @ 2ohm, the sub rated 750rms, so i still can raise the gain to get at least 3/4 amplifier's efficiency
Yes, replace the small ground wire with one the same size as the power wire.
As for your gains, yes, what I said is what I meant. Amplifier efficiency has nothing to do with the gain knob, it is the relationship between how much power the amp uses and how much it produces. Your amp can be its most efficient with the gain knob in any position, so long as that position is matched to the preamp signal.
I'll try to explain gain for you...
Let's say the amp's maximum power number is 10. And, let's clarify that anything the amp does over ten is wasted power and dangerous clipping.
Here are two examples wherein the amp above will produce 100% of its rated output of 10:
First, we have a preamp signal of 3 and we need to turn that preamp signal into 10 by the time it gets to the loudspeaker. We will set the gain on our amp to 7 and that will make the total output of the amp 10, which is 100% (or max) of the usable power the amp is capable of producing.
Next, we have a preamp signal of 6 and we still need to get that signal to 10. So... we set the gain on the amp to 4 and that gives us our total of 10.
But what happens if we set the gain at 7 with our preamp signal of 6? Well, that gives us 13, which is 30% more than the amp's maximum capability. The amp will try to make 13 but instead of us getting a usable 13 we will get a horribly clipped and inefficient 13 that will likely sound bad and most certainly will end up damaging our sub(s). Not to mention, the amplifier's efficiency will drop tremendously.
Obviously, the above example is very simplified and does not represent real voltages or power outputs but none the less, it is exactly what the gain on an amplifier does. And there is another negative affect from overdriving amplifier inputs that's not talked about much. Specifically, it's a reduction in the preamp signal that's actually used. For instance, if you over drive your amplifiers you will only be able to turn your source volume up to, say, 40%. But when the volume is at 40% on the source, any subtle sounds will not be amplified and thus, will not be heard. And, the result is poor sound quality.
Ultimately, with a properly set up system you should be able to take the volume on your head unit/source all the way to ~80% or more before you hear distortion... if you have external amps on all the speakers. If you're using an internal head unit amp for the front stage, that number will be ~50% and the result will be a higher gain setting on the bass amp because of the lower preamp voltage you'll get at half volume.
