subsonic filters
nismboy6986
the **** technician
are sub sonic filters needed for subs in ported enclosures even if you only listen to actual music with it? I'm planning on running a xxx in a ported enclosure and powering it with a jbl1200.1 and as you probally already know a fault with this amp is that it doesn't have a subsonic filter. I'm planning on getting a audiocontrol 6XS crossover that has a built in subsonic filter but it would be a little after i get the amp and subs.
As long as you don't turn the volume way up until you get a subsonic filter, it should be ok. A woofer in a ported box has good power handling above the tuning frequeny. but below the tuning frequency, power handling drops off considerably and the speaker can be damaged from over excursion.
Originally posted by nismboy6986 are sub sonic filters needed for subs in ported enclosures even if you only listen to actual music with it? I'm planning on running a xxx in a ported enclosure and powering it with a jbl1200.1 and as you probally already know a fault with this amp is that it doesn't have a subsonic filter. I'm planning on getting a audiocontrol 6XS crossover that has a built in subsonic filter but it would be a little after i get the amp and subs.
I believe a subsonic filter is super important when you have a ported enclosure. Any music that is played below the tuning frequency of the port is just wasted energy so cut it out.
nismboy6986
the **** technician
nismboy6986
Belhaven NC
bean
