Subsonic Filter
I ssf is a must have for a ported enclosure. I don't know how versed you are in car audio so I will start from the begining. When you have a ported enclosure that enclosure will be tuned to a certin freq. This is shown by ex: 32Hz. What a ssf does is that when your subs goes to play a note that is tuned lower then your box it will stop it from playing that. If you didn't have a ssf then your sub would have TONS of stress put on it and if not fixed will eventualy lead to the subs burning up. SSF's are a most have for an ported enclosure. The exception to that is that if your enclosure is tuned low enough you will not need a ssf.
Hope this helps out a little bit...
Jon
and for me can you help me,i use 2 sx 18" in a box of 15cuft,with a port of 174squinch tuned to 34hz my subsonic filter is between 20hz and 50hz
what is the best position for my installation?
thanks
CaviHitts
CaviHitts
Atlanta, GA
rick22
michigan born
    May 14, 2026
michigan born
    May 14, 2026
