subsonic filter opinion
for a 35hz tuning i would turn it to about 28 or where 28 should be on
the knob...
im conservative though so you might be able to be more liberal with it...
my box is 30hz and i have my SSF on about 27... or where i believe that
27 should be...
amps should have more accurate knobs...
for a 35hz tuning i would turn it to about 28 or where 28 should be on the knob...
27 should be...
i agree.. i want to set mine around 30 but i don't know where 30 is lol
15-40 so you have 25 hz worth of valu...
half of 25 is 12.5 so if you have your knob
turned exactly half way up thats 27.5...
if 15 is at like 7 on a clock face
and 40 is like at 5 on a clock face
27.5 will be at 12 on a clock face
now you can take the 40hz at 5 and 27.5hz at 12
you can figure that around 2.30 on the clock face is
around the mid point between your values... which
should be 33.75... which is pretty close... just turn it
a little bit more toward where 1:30 should be on
a clock face and youll be ok...
if that made any sense at all...
Draw up a graph of the knob. Slice it in half that is 27.5hz right in half. You want to get more accurate slice those two in half now you know where 21.25hz and 33.75hz is...
It's not really rocket sience. Of course you will not be 100% accurate, but at least within 1 frequency.
How do you know where to set it?
Like my new box is going to be tuned to 34 hz, and my bx1000d has 15 on one side and 35 on the other...
What is a safe ssf setting for a 34 hz box?
the thing with the ported box is if the sub plays below
the tuning frequency it can become out of control and
you can potentially have problems...
not a lot of regular music has enough of those super
low frequencies where it will necessarily become a
problem even without an SSF...
the SSF is an extra measure of safety for your sub...
like trigger said... its not rocket science... but it is rocket science...
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
psych0ticnemes1
Mike Mccabe
