Subs to go with Rockford 1200w 2 channel amp
How would 2 mach 5 12's sound with the bash 300 amp, specs are below, just a thought... will that be nice and ****ing loud... or get a more powerful amp!?
BASH-300 delivers a solid 300 watts into 4 Ohms with low distortion. Includes variable crossover, phase adjustment, high and low level inputs. Bass boost of 1db at 30Hz which can be adjusted by changing two resistors.
Power Output: 300 watts at 4 Ohm
THD: 0.5%
Low Pass Crossover: 50-150Hz
S/N Ratio: 105db
Input Impedance (Line): 20k Ohm
Input Impedance (High): 220 Ohm
Damping Factor: > 500
Standby Power: 18 VA
Dimensions: 27.9cm x 17.8cm x 8.9cm
syntheticwaste
syntheticwaste
San Francisco, CA
syntheticwaste
