Subs stopped hitting hard overnight
JVC KD-X50BT Headunit
- Duel 10in Alpine Subwoofers.
- Wired under passenger door still
- The subs and amp are in Fast and Furious 1.
- V12 Alpine amplifier.
- Where I ground my subs, there was already a hole and I just dremeled the paint away.
Car is a 97 Audi A4
Anything else you need to know?
So my subs stopped hitting hard overnight. They are still moving. My system was working fine earlier this week.
What to do?
Check what ohm load your subwoofers are at on the amp using a Digital multimeter. Make sure all the settings are the same. Ya could have blown a coil, a former or Many other things. Stat by checking what your subs are wired at. Maybe a wire fell out a terminal.
Obviously some sort of connection issue. What happened to the ports on your box?
This here for sure especially if it randomly started back working again..Id also look for a better means of ground,a bit more solid,but...its working for you.Loose wire somewhere to check for.
King_Life
King_Life
Canada, Eh?
audiobaun
