subs sound weird
would you say the SPL intensity has changed???? or does it just sound different?
really both, sounds like its missin a range of frequencies. like above 50 hz it sounds ok, but lower sounds really bad. i thnk its bottoming out.
it had just started happen.
give more info, what box, how long aog has it started happening, did u do anything with the system prior to this, weird smell in the car(coil burning) etc?
i had this system in my car for 7 years. the box is prefab like 1.2 cu ft per sub sealed, just started probably this month. naw didnt do anythin to the system.
i burnt a mosfet on the amp last month(its a pyramid amp i know i know //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif) . but amp still worked and system sounded fine. but all of a sudden it starts soundin like this. And no smells from the car.
and check for dc output from the amp
edit:
Just read the mosfet thingy... Internals on the amp shorted out and you still didn't take it out of the car? Do you have children or anything? Great way to try to set them on fire if you do.
Lets Get It
Lets Get It
Where im at
skydeaner
