subs overpowering
is there a setting on my hu do you think that controls the volume of just the front/back door speakers?
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
you can turn the gain up on your fronts......but really you just need a better front stage.
when you say better front stage, you mean mroe speakers or better speakers? i just bought these and am out of cash now so buying more is out of the question, anything i can do without spending more cash? ill try turning up the gains
Aiee..
No, don't do that... Don't want to clip out the front amp.
What you need is something like a bass control knob for the amp - you set the gains with the knob maxed out, and then if it's overpowering, you just use the knob to turn it down in the front.
Alternatively.. On the HU, it's likely there's a bass setting - you'd need to check the manual for the HU, or list off the model # for us.
if his gains are set right, he shouldn't touch them. This mean you need better/more highs. I read if you have to mess with you eq, you don't have enuff power/speakers. Like if you have 4 18"s and have to turn up the treble, you need more components. Eq should be set flat and everything is suppose to be heard.
i have a bass control knob. i want to keep the bass as loud as it is for when i want to show off. ontop of that, i want to turn up the door speakers (on a different amp) when its that loud, becuase the subs overpower it. so like a control knob..just for my hifonics amp for my door speakers
how much power are you feeding the front stage?
Problem is budget. If the bass is overpowering the treble, and you can't afford a better front stage, nor a better amp for them, then the only thing to do to balance the sound is turn down the substage.
As for bass control knob.. I meant a remote one - up at the front, so if it's too loud, you can just turn down the knob, and then turn it back up if you want to impress someone.
Make sure the gains are set correctly for the front - if they are, then there isn't a thing you can do to safely make those louder without putting out some more money. You'll either have to turn down the subs or get better speakers and/or amp.
taintedplay
taintedplay
dallas
Talon
