You don't turn your subs on unless its over 70 degrees?As long as they arent playing they will be fine, but the cold will cause a viscosity problem with the subs and cause them to tear around the top. but if you don't bump them they should be fine. I have mine off if it gets less than 70 degrees outside
you sir are an idiot //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifAs long as they arent playing they will be fine, but the cold will cause a viscosity problem with the subs and cause them to tear around the top. but if you don't bump them they should be fine. I have mine off if it gets less than 70 degrees outside
