subs from EbAy?
FLEX4U18
va
ok, i am searching all over ebay for good cheap subs. i came across the pioneer premiers for like $100, kickers comp for like $125, alpine type r for $215 and jl w6(older ones) for about $150. they also have sonys for under a 100 dollars. i am looking for 2 12's 400-500 max each. i would really appreciate it if someone would help me out. i am gonna run them from 800 watt crunch amp. gonna get them by next week. also need to know what kind of box should i get. thanks
All the subs will get the job done...whatever you get depends on the rest of your setup and your personal preference......what's the RMS on the amp and @ what ohm load? Are you looking for SQ or SPL?
Originally posted by Gauntlet All the subs will get the job done...whatever you get depends on the rest of your setup and your personal preference......what's the RMS on the amp and @ what ohm load? Are you looking for SQ or SPL?
the amp is bridgeable @ 2ohm. 800 WATTS X 1 @ 4 OHMS. so shouldnt i get 2 subs 400 watt each?
Originally posted by FLEX4U18 the amp is bridgeable @ 2ohm. 800 WATTS X 1 @ 4 OHMS. so shouldnt i get 2 subs 400 watt each?
Yeah...around that area....the subs will have to be dual 4 ohm, or single 2 ohm....are you looking for the subs to be loud or sound good?
Originally posted by Gauntlet Yeah...around that area....the subs will have to be dual 4 ohm, or single 2 ohm....are you looking for the subs to be loud or sound good?
well i want the subs to have deep bass and hit hard.
Originally posted by Gauntlet I'd say go for the Comp VR's or Pioneers from your list
I agree. You should be able to find a pair for about 150 or maybe some rockford fosgate he2's if you can find them for that price
Originally posted by Jmac The Premiers are much better SQ-wise than the Kicker CompVRs. Not sure what JLs you're talking about, but I'd say the Premiers are a lot better than the W0s, but not quite as good as W3s ...
And DHD doesn't make anything that's even remotely good, to my knowledge ...
jl w6. what about dhd's?
FLEX4U18
FLEX4U18
va
Gauntlet
