Subs Firing Angle?
Cali_Screw
So im going to be doing a build for a buddy of mine, However im not to sure what type of box to do. He will be running 4 10" subs. This box will be in a Nissan titan pick up truck. Now my question is, should we do a up fire box or a forward fire box? any pro or cons?
Why is he letting you build his box if you dont know how? Subs up, port up... What subs and amp are you running. How many watts is the amp at 4 ohms RMS and what is the power handling of each sub?
who ever said anything about a port and running at 4 ohms..
have you ever dealt with a sub box that goes under a seat of a truck?
Didnt say in your first post where the box was going.
But yes I agree that subzero brought things out that dont really matter in this post.
i do have to agree my first post was vague about the setup.
To possible clean things up and get a little more input.
Subs will be 4 ten inch Alpine type R's sealed
Off of two T1500 Rockford amps.
Box will be under the back seat, so i can either up fire the subs or forward fire. Forward fire would give a slight more advantage in airspace of .2 but can cause issues as subs could be kicked and be damaged.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Where are you getting all of this invisible information?
The voices coming from the walls...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But it's all good, the house was cheap with a great view of the lake and a boat dock right down on the water...
i had 12 g3s in my titan with 2 gtrs the pics are on here somewhere a couple of magnets will give u a seat lift in that truck and give you more space. my back seat was more comphy with the seat lift. if he want to save some head ache i still have that set up i will sell him
Cali_Screw
Cali_Screw
Rancho,CA
PV Audio
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
