yoratbastard 10+ year member
This may be for the more advanced installer/users. What are the benefits of Serial Wiring vs. Parallel Wiring?? I have a 4-channel amp running front & rear speakers and a pair of 10" subs in a single sealed cabinet (each with their own wiring connectors). I've changed cars and wanted to reinstall the system with the same amp on the front & rears, but add a mono amp for the subs. If I connect each of the subs connectors to the mono amps output (parallel mode), won't they split the total power output?? The subs are both 4 Ohm SVC. If the mono amp is 2 Ohm and both subs are connected to the amps output (parallel mode), wouldn't the 2 subs each get the total power output??
I know it is a bit confusing, but I'd like to understand what's going on before I spend money on the mono amp.
Thanks in advance...
