sub selection
try the kicker comps or comp vr's if you wanna spend the extra dough. they are a very versatile sub, and you can put them in any box, even freeair. ive got 2 comp 10's and i love them. the only difference between the vr and the normal comp, is the vr has more power handling, therefore it is louder.
good luck
well this is a difficult question to ask. how about giving us a few specs to help with a good recommendation. such as how much money to spend on each sub?? how much room you have for the box?? last but not least what kind of amp you plan on using to power them??
adam
here are some specs,
kicker comp c12
polypropylene cone
polyester foam surround double stitched to the cone edge
can be used in free-air applications
frequency response 25-500 Hz
power range 30-150 watts RMS
peak power handling 300 watts
sensitivity 88.6 dB SPL
top-mount depth 5-5/8"
sealed box volume 1.25-3.5 cubic feet
ported box volume 2.0 cubic feet
price: 89.99 us (crutchfield)
kicker comp vr
mica-filled polypropylene cone
Santoprene rubber surround
dual 4-ohm voice coils for wiring flexibility
power range 50-400 watts RMS (200 watts RMS per coil)
peak power handling 800 watts
sensitivity 86.7 dB SPL
top-mount depth 6"
sealed box volume 1.0-4.6 cubic feet
price: 149.99
Alpine Type S
Kevlar®-treated pulp cone
3/4" Santoprene rubber surround
frequency response 26-1,000 Hz
power range 50-200 watts RMS
peak power handling 600 watts
sensitivity 89 dB
top-mount depth 6-1/2"
sealed box volume: 0.85-1.5 cubic feet
ported box volume: 1.25-2.0
1-year warranty
price: 129.99
Alpine Type R
Kevlar®-infused pulp cone
1" Santoprene rubber surround
dual 4-ohm, 2" voice coils
frequency response 24-1,000 Hz
power range 100-300 watts RMS (150 watts RMS per coil)
peak power handling 1,000 watts
sensitivity 87 dB
top-mount depth 6-15/16"
sealed box volume: 0.7-1.0 cubic feet
ported box volume: 0.75-1.75 cubic feet
1-year warranty
price: 199.99
MTX Thunder 6000
frequency response 29-150 Hz
power range 50-250 watts RMS
peak power handling 500 watts
sensitivity 87.2 dB
sealed box volume 1.0-2.0 cu. ft.
ported box volume 2.0-3.0 cu. ft.
1-year warranty
price: 139.99
mtx thunder 8000
frequency response 23-150 Hz
power range 75-400 watts RMS
sensitivity 85.8 dB
top-mount depth 5-9/16"
sealed box volume 1.0 - 2.0 cubic feet
ported box volume 2.0 - 3.0 cubic feet
1-year warranty
price: 249.99
Rockford Punch
frequency response 27-200 Hz
power range 50-100 watts RMS
peak power 200 watts
sensitivity 88 dB SPL
4-ohm impedance
top mount depth 4-7/8"
sealed box volume 1.25-1.75 cubic feet
ported box volume 1.5-2.5 cubic feet
price: 59.99
Rockford Punch Z
silver polypropylene cone with black foam surround
silver LXcursion steel basket
four-layer voice coil
frequency response 20-200 Hz
recommended power range 50-150 watts RMS
peak power handling 400 watts
sensitivity 90 dB SPL
top-mount depth 5-3/16"
sealed box volume 1.0 to 1.75 cubic feet
ported box volume 1.75 to 4.0 cubic feet
1-year warranty
price: 79.99
Rockford HE
frequency response 28-200 Hz
sensitivity 87.6 dB SPL
4-ohm impedance
top-mount depth 5-3/4"
ported box volume 1.5-2.0 cubic feet
price: 129.99
sony x-plode
high-rigidity compound polypropylene cone
frequency response 20-2,500 Hz
power range 50-300 watts RMS
peak power handling 900 watts
sensitivity 89 dB
depth 5-3/8"
recommended sealed box volume 1.0 cu. ft.
1-year warranty
price: 99.99
sony x-plode alum
aluminum cone
4-layer voice coil
peak power handling 1200 watts
sensitivity 89 dB
depth 5-5/16"
1-year warranty
price: 139.99
Well hope that helps ya out!!
DAN
Look into the RE SE 12. The direct price for it is 159. All of their subs were built with SQ in mind but also have very high output. I think you would get more for you money with this sub as opposed to kicker comps or type r's.
i own a 15" inch kicker and its everything i dreamed, i'm breaking world records left and right. //content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif yes that RIGHTS! MUAHAHAH
i wounldnt buy sony subs ether for one u cant get dual voice coils and the box has to be as close to one cubic foot as posibble and thats hard to find un less u make ur own box i had a sony 12 red cone and it was great for a while (3 months) then it blew witch was cool cause i saw it shread apart cause my friend pit it on his 1000rms amp and it riped apart it was cool but now i have two 12 audiobahns awc12s they pump hard i got mine at a whole sale store for 210 bucks w/ a box (did i mention there dvc too)//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I hate sony subs i could recommend the kicker vrs but if your looking into SQ with some SPL try the JL w6's they hit really hard while staying clean
thanks
rick
big round ones....//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif :p:
wow....WOW....WOW //content.invisioncic.com/y282845/emoticons/wowflash.gif.89a61f4caede63a11dac36e97d61323e.gif
this is freakin old
430
435
562
685
DeKaL44
DeKaL44
OH
Chevyaudio
    May 31, 2024
    May 24, 2024
