Sub quit playing while driving...help
Carson45
I wired my car up today to put in my sub and amp. Everything was going good till I decided to turn the sub up a little more on my head unit. It sounded really good then the sub shut off. The amp is still turning on but Im not sure what happened. Nothing at all is coming out of the sub. any suggestions?
if you had a sub that over powered you should have noticed....unless you've never heard a stereo before?
Does amp throw a protect light?
Take out the sub and look at it, could be as simple as a loose connection
267
433
538
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
855
538
Carson45
Carson45
nashville
Sarthos
    May 18, 2024
    May 18, 2024
