Sub problem, wont work unless u push or tap it.
  • 2
calebkhill
Tried hooking up some 15"s I used to have, and noticed only one hits. Before I took them out of the jeep (motor blew up), base would get hard then soft. Never checked it out real good, thought it was the amp, but after today I noticed only one works.
As for the busted one, it wont hit uunless i push or tap it, itll hit for a few seconds then cut out. And while it is hitting its not real clean.
I already googled around and most I could find was that the tensils may be bad. I actually did take it out and npticed one tensil wire seems to have a bad spot, looks kind of burned or something. Think cutting and resoldering this are may fix it?
Could tere be any other sources to this problem?
There is no noise or tightness when I push the cone.
Also, itsa single voice coil 8ohm RF sub.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
617
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
683
That does sound similar to what mine does, I'll take a video and post it this weekend so you guys can weigh in.
23
5K
calebkhill
calebkhill
Phenix City, Alabama
calebkhill
    May 12, 2024
Brendon Jenness
    May 11, 2024
