Sub mounting
uzy
O
hey
what difference will it make if i am to mount my kicker L7 so that the magnet is out off the box and its baisicly screwed in upside down, so that the cone faces the inside of the box. also how do i make sure the box is sealed as i think air escapes from were the screws are put in
and when you screw the woofer in, make sure its in tight. and it wont leak air.
i made sure its tight as i put the screws in with a drill and i can still hear air escaping when i push down on the sub
duck tape it lol if you dont care bout looks which you prob do as most do
would insulation tape work, also i got sum foam strips with a sticky back could i use that to line the face off the sub so when its put onto the box and screwed on the tape will ensure a air tight fit
uzy
uzy
O
uzy
