Sub mounting hardware
Super glue //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
T nuts are great. But regular drywall screw work fine for subs that arent extremely heavy or mounted facing down or something. just predrill your holes first
ya They are down firing and I think the t nuts sound like the best option Thanks for your input also can i ask what you would recomend for speaker wire ? I am waiting on 2 C2 Threatcom 2 s 12" and am running a Kicker zx 1500.1 to power them ? its a short run maybe 3 ft total
course thread drywall screws and pre drill the holes. Or SPAX 1 1/2" #10 screws if you have monster subs.
Do NOT overtighten the screws and you won't have any issues...
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
If you have an OEM radio and amp, chances are that one has bass reduction as the volume rises to protect the paper cones from tearing apart. So if...
83
299
ChaseinBass
ChaseinBass
Calif
RicksI30
    May 20, 2024
    May 20, 2024
