sub in port
jellyfish420
i design boxes .......
what would happen if i put the sub in the port like this? doing something like this is the only way i'd be able to get my desired box volume, and port area. maybe flare it at the mouth? anyways, any suggestions? ANY
If you can get that much port area and volume that way, you've got to be able to do it with the port in the back too I would think....and even though that's not optimal, it seems like it would work better than what you're proposing. I really don't know though, never seen anyone do it like that.
I don't think that would work....
With the sub firing like that I would image it would *disturb* the sound waves trying to exit through the port...
Then again, you could have the next *snail shell* design or whatever... Try it, if it works it would deffintely have an unique box.....
P.S I'm not an expert, so totally disregard my statement above... //content.invisioncic.com/y282845/emoticons/chicken.gif.218ea7401db50d5e31a7e0b37e05e21e.gif
in that vid where the guy used the membrane to make a loud 6.5 the speaker was mounted at the end of the port. i say go for it and see how it sounds. maybe if you can get the sub position just right to where the air coming from inside the box leaves the port at the same time the air that the cone moves does may reinforce eachother. (I dunno what im talking about) id think youd want a pretty wide port so the outer wall is far enough away from the cone though.
jellyfish420
jellyfish420
STL ill side
jellyfish420
