Sub Hook Up
xterra02_pat
Alright So I have this panasonic CQ-VAD7200U in-dash. Im trying to hok up my subs but the RCA's that I currently have in my car are the normal 2 plugs on each end. In the diagram on the website for the manual... which can be found here http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportModel?displayTab=R&surfModel=CQ-VAD7200U&modelNo=CQ-VAD7200U&storeId=15001&catalogId=11017&itemId=62752&displayServiceCenter=true# page 76.... is shows the Sub RCA having only 1 plug on the end going intot he brain. On the brain itself there are 2 black Sub inputs but when I hook up my RCAs into eaach i get nothing. My amp is DEF getting power I checked it with the multi-meter. Do I need to get one of these RCA cables? If so any idea where I couldn't find them at radioshack
OK, so I got the sub playing now, but it only plays on Radio?!?!?! When I turn to any of the other inputs, like where my ipod is connected, no sub? Also when the dvd or cd is playing, no sub? Any idea?
Yeah it sounds like you have the remote line in the back of the headunit wrong. You probably have it hooked up to power antenna instead of remote. The remote wire goes to the amp to tell it to power on.
That's a weird one. Sorry. Does the manual say only use one Rca? Try running a wire from your positive on your amp to your remote on the amp and see if it powers up. Cause it might be a bad remote wire.
xterra02_pat
xterra02_pat
Randolph, NJ
Little B
