sub box
Do you mind telling me what that is? Help please. lol im a newb and can you answer the fuse question for me? I have an 80 amp fuse in right now but I dont know if its to big or not?
Polyfill is polyester filling... the stuff you can buy at arts and craft stores or even walmart in the fabrics and crafts department for about a buck or two per pound. Here's a basic explanation for use.
As for the fuse question, I'd personally go with 4 gauge for a 60A circuit.
Is it ok that I am using 8 guage. I had the shop install it and Id hate to spend even more money just to have a new wire run through. As for the fuse, would it be dangerous to use an 80 amp fuse or should i just run 60 amp? I will be keeping the 8 guage, the shop said it was fine.
If you use the 60 amp fuse, it might blow on ya but, that might be a good thing because like said earlier 4 gauge would be much safer. So either run the 60 amp and it might blow one day (safe but a pain) or run the 80 amp and risk a fire or do it the right way and run 4gauge wire..
clubcar13
clubcar13
Boca Raton, FL
Rich00
