Sub & Port direction in a truck.
reclessantics
SC
Basically what it says. Silverado 1500 ext cab. I took out the back seat and made a platform for the enclosure to sit on. Its a 10^3ft net box, for 2 18'' mach audio mj 18m's.
I want to go with subs up, and port up. (port all the way to the passenger side of the box) (id prefer middle but wouldn't work im sure)
any suggestions or would this just cancel out? should i go subs forward, port up?
i wouldn't point either up. i have an s10, and it didn't work as well up, as both forward. subs forward, port to a side seems good. downfiring worked well also. when i did subs up, i seemed to lose audible loudness using the same equipment.
word, so no port up either?
i have this lame sub that i tried up facing up and forward. i didn' tknow which would be best.
i thought if both sub and port were in the same direction, they could cancel?
i don't think i would downfire
my dims are - height = (want 16'', but can go 20'')
depth (front to back) = 28''-30'')
width = 60''
what would downfiring do?
its on a platform that sits basically level with the a ss part of the front seats. no back seat, all space
389
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
574
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
570
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
reclessantics
reclessantics
SC
reclessantics
Brendon Jenness
    May 8, 2024
    May 8, 2024
