Stroker 15 Box Test Sheet ?
crownvic02
I bought two cerwin vega stroker 15.4, they came with a test sheet of how the subs perform in the sealed and ported enclosures. and resultes between 30-40hz was that sealed out did ported in db ratings. sealed enclosure rated 83-87db, and in a ported enclosure tuned to 36 hz, it was rated 80-84dbs, so does this mean i would get louder with the sealed enclosure
no it means that at that frequency...sealed box was more efficient. how loud you get depends on the power, vehicle its in, the enclosure design/shape/space/placement. I believe bench tests mean not much in a real world application.
Ok its all going in a crown victoria 2002, ok and I'm giving it 2600 rms power which would u suppose be better because most of the music I listen to hits between 25-40hz I like low bass and alot of the music I listen is also screwed so what do u suggest
crownvic02
crownvic02
Orlando, Fl
crownvic02
