Strapping Kicker Amp Questions
Winter_C
Teh Pinto Driver
Ok, So I read the manual and figured out how to strap them...but still confused on a few things
I am strapping 2 Kicker KX1200s to 3 Rockford P3s that are at 2.67 ohms.
Here is the manual if you would like to see: http://www.kicker.com/sites/default/files/04KX%20400-600-1200_1%20Amplifiers.pdf (Page 6 for Amp Strapping)
But in that it shows only 1 set of RCA's going into first amp, but not into 2nd...So I only need 1 set ran?
And could someone explain what the "Strapping" input on the amps actully do? I talked to a Kicker dealer here in my hometown yesterday and he had never actully strapped amps, he told me just to run 1 coil off each sub to one amp and other coil to other amp, I know that would work....But doing it that way you have to have each amp EXACTLY matched or risk frying a coil....So I am wondering how setting these amps up works now with the strapping cables?
If someone could explain, I would be very appreciative.
Winter_C
Teh Pinto Driver
Winter_C
Mitchell, SD
Winter_C
BP1Fanatic
BP1Fanatic
