Stock Wires
Fender5
Since I can't get the wires through my Honda Accord, i'm going to use my stock wiring from the harness. and just tap into it. however, i'm going to have 125W RMSX2 so 350W RMS runnin through constantly. My car did not come stock with any type of infinity system or anything special. not sure if that matters.
so is 350W RMS runnin from the harness to my amp going to bad for the stock speaker wires?
What the F*ck are you talking about? Your connect what to your wire harness?? Lmfao? you gonna connect your baby amp to your wireharness? Are you that much of a cheap *** you can't spend 20$ on wireing and run a power wire to the amp??? Run a baby amp into your 16gauge wire harness and see what happens. . .
i shoulda added this to my question..
I have the Image Dynamic Ctx65Cs and i cant get my Stinger 16 gauge wire through the door into my cabin because of the molex plug.
so im going to just use the stock wires that would originally go into the head unit but twist the 16 gauge onto it and run it to the amp which is going to be 350W RMS
i shoulda added this to my question..I have the Image Dynamic Ctx65Cs and i cant get my Stinger 16 gauge wire through the door into my cabin because of the molex plug.
Dude your shit is confusing, Buy a drill and a drill bit.....problem solved
u sure it wont go through or are you being lazy??//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Trust me, you will NEVER hear that little bit of difference in going from your regular speaker wire down to your stock speaker wire for those last few feet! Go **HERE** and estimate the length of your stock wire to come up with resistance.
OTOH, I curse HONDA and FORD for using those friggin molex plugs! My passenger side on both cars has room to run wires through but my driver's side does not! I am not anal enough to remove my fenders and/or doors just to run new speaker wire.
Fender5
Fender5
Arkansas
Fender5
