Stock HU and 8-pin DIN connector (Acura)
  • 2
GSR Jay
Canada
No one has been able to answer this post no matter where I post it.
I have a 1997 Acura Integra GSR with the factory CD head unit. I've been wondering if there is a way of creating an RCA type stereo input connection using the 8-pin DIN connector from the stock CD player that is normally used for the optional CD shuttle. What I want to do is hook up my Mini-Disc player to my radio. It's a Sony with MDLP capability so I can play like over 4 hours of tunes from one disc. I do not want an aftermarket deck as I'm satisified with what I have now (read broke). I don't have the tape player.
This site shows a good pin description of the factory DIN socket:
http://integra.cyberglobe.net/carau...agrams/DIN.html
How do the deck and CD changer communicate through that DIN cable? Two of the pins are designated R and L designating the left and right channels I'm assuming. Is there a way that something could be rigged up to fool the deck into thinking that a changer is connected to it? Any electronic guru's here?
Jay
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
373
620
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
419
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
576
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
GSR Jay
GSR Jay
Canada
AlpineGirl
    May 19, 2024
    May 19, 2024
