stock gm head
hey there. first time poster here.
does anyone know if a stock gm headunit from an 2008 chevy silverado 2500 hd duramax diesel has pre-outs or if there is any way to add a subwoofer to the stock radio?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused: any help and info would be apreciated.
i dont really know what a substage is as im not really an audioexpert like many of the great minds on this forum:respekt:. could u explain it 2 me?
Substage is exactly what it sounds like... the sub woofer "stage".
Your car probably doesn't have Pre-outs. However, you can buy something called a "Hi-Low Converter" which converts your speaker outs into an RCA-out, which can then be run to your amp. I've done this so far on my brother's truck, and I can't really hear a difference. Those are about $20 bucks.
However, I believe Pioneer makes a unit that acts much the same way as the 'Hi-Low Converter', except it's much higher quality, and has an onboard EQ and IIRC, is a 3-way. (It has pre-outs for subwoofer, mid-range, and high. But, you can change the mid-range to full range, and the high to full range, too, I believe.)
That processor will run you about $80 bucks on woofersetc.com.
thanks idskot. im gonna look into that converter. u wouldnt happen to know any companies that make custom fit boxes for ext cab trucks do u ?
probox
proboxrocks dot com
they make some really good stuff. it can be expensive though depending on where you get it from
danny666007
danny666007
stamford, ct
allout13
BP1Fanatic
BP1Fanatic
