Sold Stinger SPV-70 $100 Plus shipping
Cutdawg84
I actually have 2 of these left, 1 is pending right now.
I bought these back when bumpin buick was moving these like crazy. Never got around to using them ( my project is at a stand still).
Asking $100 plus shipping.
Buy these //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Here is some info on these batteries that I found
Internal resistance
5 Second Cranking 1050 Amps
Weight 57.3 lbs
Constant Discharge Capacity at 77 degrees to 10.50 Volts:
20 hour rate: 3.5A/70Ah
5 hour rate: 11.9A/59.5Ah
1/2 hour rate: 87.5A/43.75Ah
CCA: 875 Amps
DIMENSIONS
SPV70 6-7/8" H x 13-3/4" W x 6-1/2" D
(Add 5/8? to height for battery post)
General POWER Series Specifications:
Temperature Range: -15 to +50 C
Typical Cycle Life: 350 cycles @ 100% depth of discharge (10.5v)
Maximum Charging Voltage: 15 Volts (Cyclic Use) 13.8 Volts (Standby Use)
I have to disagree with the weight in that info I just posted. At the ups Store they weighed in about 60lbs a piece. Shoulda seen the little girl's face when she tried to move it off the scale //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Cutdawg84
Cutdawg84
Columbia, TN
king ranch
