Sold Stinger SHD4MAX - Digital MAXI Fused Dist. Block (4 position) NIB $20 shipped
bucac_tau
New in box Stinger SHD4AGU - Digital AGU Fused Dist.Block (4 position).
High amperage fuse distribution is simplified with Stinger’s MAXI fuse distribution blocks. This custom block utilizes modern style MAXI fuses that simply plug into the high tension spring tabs for minimal resistance. For use with MAXI style fuses up to 80 amps.
Four Position MAXI Digital Fused distribution block with 0 or 4ga input 4 or 8ga output. Integrated voltmeter informs you of system operating voltage while super bright blue LEDs and a warning buzzer alert you of fuse status. All this plus killer new styling of polished platinum finish, bright blue base and chrome and blue Stingerlogo button.
$20 shipped
bucac_tau
bucac_tau
Orange County, CA
bucac_tau
