Stinger Distribution Block Problem
d4m4g3
im running 3 jl 12's w1 in a sealed box off a kenwood 1800 watt amp and have no problems with the sound.
The 2 problems i do have are:
1. My distribution block makes a constant buzzing sound.
2. My head lights flicker slightly.
My lights use to dim drastically untill i got 2 capaciters installed. After the 2 caps i got the distribution block and installed it.
im running 1/0 power cables and ground cables to the block and 4g out to the caps on one side and to the amp on the other side.
Any one know how to stop the buzzing and the dimming of lights.
Typically dimming should be addressed in the order of:
1. Big 3
2. Upgrade battery or additional battery
3. HO alternator
Cap = Crap
No clue about the distribution block buzzing...what is the make and model?
Yeah, sorry, meant model, not make. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
If it's buzzing, maybe it's defective? Especially if you are getting buzzing but your voltage is well above the aforementioned minimums.
The grounds good //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif im sure of that.... im guessing its just defective.
so im assuming i need a new battery and new ground for alt.
i only pull 78 amps max well so the distribution block says and my alt is 70 at idle and 120 moving.
d4m4g3
d4m4g3
M-town Tx
d4m4g3
