Still clipping?
scottyk
lil' nig
344
NY
Getting some clipping issues still with my 2 DD 1508's running off of my AQ 2200D. To the best of my knowledge, I don't think the big 3 should cause this much of an issue but it seems to be the only thing I really need?
I've got 0 gauge running to the back, an Optima redtop up front, big ole' GNB sprinter battery in the back. Stock alternator, but I know there are plenty of people on here running the wattage I am with a few stronger batteries and no real issues.
The 2200D comes with that handy bass control knob that has the clipping light and it shows clipping at only about half way. I haven't done the big three yet, but even still, would just not having that electrical upgrade alone cause me to not be able to turn the knob up nearly the other half of the way? (not saying I would for the woofers sake, but I'd like to give them a little more juice).
Any opinions?
Any of the amps I've owned with a clipping light has looked like a strobe light!
I'm on the verge of a clip alllll thhe tiime
So should I not be paying so much attention to it then? My knowledge of it isn't complete, but clipped signal means trouble for your speakers pretty quick, does it not?
Ok, ill keep that in mind!
But I guess now I'm just wondering is shouldn't the two batteries I have be able to produce enough watts for my amp? I planned to later get some nice components and amp them as well, that will only further compound the issue? I assumed both of these batteries would do just fine for. 2k
depends. if you have a 100 watt sub and use an amp that puts out 10 watts and you clip the hell out of it, it wont hurt the sub
a little clipping won't hurt
remember it's not the clipping that can be bad, it's the extra power that comes from it that can be damaging
x2
iirc, full clipping is LIKE putting out as much as 2x the power
So then I guess I gotta ask, what causes clipping? I thought it was from insufficient electric? And my other question is, if my gain is too high, how can I set it so I'm giving each of my 8's around 1k a piece without clipping?
scottyk
lil' nig
scottyk
NY
Chrispy
BP1Fanatic
BP1Fanatic
