so the amp doesnt do rated power at 1 ohm at 12v.... I'll pass
The amp is a modded 7k board that made over 6500 watts or whatever with 16v batteries that were not fully charged. We don't even know what type of batteries and the age of those said batteries. I haven't seen anything publised stated a 12v rating on the 10kd. It did make the 6552 at a drop of 12.4volts so what would it make if he had the battery support to maintain close to 16-18volts. I say get batteries charged up and add a few and then do the test again. I think this amp shines in a competition setting mostly. Specs from site. And of course those are bench results.
V 10Kd
Technical specificationsRMS Power @ 16.0V Mono 1 Ohm 13700 Watts
RMS Power @ 14.4V Mono 1 Ohm 11600 Watts
Number of Channels 1
Minimum input sensitivity 0,2V
Total Harmonic Distortion
Signal to Noise > 90 dB
Subsonic Filter Frequency 20 to 80Hz
Crossover Frequency LOW PASS 50 to 8 KHz
Frequency Response: (FULL RANGE) 20 Hz to 8 KHz (-3dB)
Power Tension 9 to 15V
Consumption with musical signal 6 to 390 A
Consumption with BASS signal 6 to 780 A
Dimentions (H X W X L) 70 x 280 x 688 mm
Weight 10,4 Kg
