Stereo going out
Tiger Bass
Setup:
-Stock 92' Camry
Problem:
Every so often, the sound goes out this stock setup. Its only the speakers when it goes out, ie. Headunit stays on. You can turn the channels and everything but no sound. And its all four speakers, not just one or two. When the speakers do come back on, they pop and are fine afterwards. I was thinking that some of the wiring has come loose over the years. The thing is that I cant really think of where it would be happening at to make all four speakers go off at once. Plus I dont want to start tearing my dads car apart without knowing where to look first.
Sounds like it is the deck going out. Bad solder joint in the head units amp or something. You can check the connections at the back of the head unit to see if a connector is working loose.
Ok thanks for the input. I went to look at it myself a little bit and was starting to think that the head unit could be the cause itself. Was going to take it into the audio shop tomorrow to get a multi disc changer put in but probably getin a real HU instead //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Tiger Bass
Tiger Bass
SC
Tiger Bass
Mike Mccabe
