stay with kicker or move on
looks like i was wrong its a 257 amp altr at 6000rpm at the altr
what is the idel speed at the alr and ill tell you what the output is truck idels around 5-600 pully size would put it about about what 1500-2000 rpms so it would be around 100
around 100 sounds about right
the 257amps @ 6k rpm's you will never see unless you are stuck spinning your tires. even at highway speeds it will never be near that
around 100 sounds about rightthe 257amps @ 6k rpm's you will never see unless you are stuck spinning your tires. even at highway speeds it will never be near that
have you road in my truck it see 6k on the motor alot //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif and with the pully gear would it be about 4800-5300 would be 6 at the altr
personally ive used kinetik for a long time. they arent exactly the best out there for burps but for daily they do very wellyou could look into batcap
yeah I wanted to use those but they are hard to find in iowa and shipping is alot for big batterys //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
For starters, you can try a different box. Try firing the ports to the side instead of forward. You are probably getting a good amount of cancellation with your current setup. I like the dual alternators nice clean install.
I am not a fan of Kicker at all, but I would experiment with the enclosure before buying anymore equipment.
x2 on the box, i enjoy my subs forward port UP.
no i havent been in your truck
if you are running 5k+ rpm's your engine is going to hell
my z71 running 75-80mph was right around 3200rpm's
running 37inch tires
1loudZ71
1loudZ71
iowa
1loudZ71
