starting a box for my silverado 2 10" r's
  • 2
thur5d4yf4n
I got tired of my subs being all sealed up under my rear seats so i decided to pull my jump seat in the front row and replace it with a ported box. these subs performed so much better in a pre-fab ported box in my old suburban, so i'm bringing it back, this time in a custom ported box. came up with this design: let me know if it looks ok. if somebody can atleast double check it and give the OK i will start cutting tomorrow and will have pics up. subs are alpine 10" type r swr-1041d. these are the old style 300 watt rms subs, dual 4 ohm. thanks
http://www.subwoofertools.com/forum/ported-box.asp?Ew=14&Eh=16&Dia=4&Xmax=13.8&Vd=.16&NumW=2&Vb=&Fb=&Qts=.41&Vas=1.02&Fs=30&CE=0
Devin
that box will sound good with the right amount of power.
subs up port firing.....?
subs up with port firing towards rear is what i would try.
but from my exsperence with those subs in a x-tra cab they sound best behind the drivers seat with subs up port firing towards passenger.
My wonderful cuts using a jigsaw
My work bench:
Tomorrow I cut holes for subs, glue and screw, then let her rip. then i will pretty it up if it sounds good.
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
ok so i realized the one u gave in the example did the same video stuff so i see the one mentions 13 band equalizer but the other has "higher"...
17
411
760
602
thur5d4yf4n
thur5d4yf4n
Glendale, AZ
thur5d4yf4n
    May 16, 2024
    May 16, 2024
