SS Rl-i 8" power
Ratings are for a reason.
CT
To break them //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Should be fine with 600rms, i would be more worried about it failing mechanically more than anything, watch your subsonic especially ported...
what do you mean by failing mechanically, also I heard about subsonic note, what does this mean, also will i have to watch for them listening to rock/techno and in a sealed box, thank you
You should be fine sealed...
There are two ways a sub can die: Thermally meaning the voice coil becomes too hot from too much power and/or clipped power, as well as mechanically, meaning the sub moves too much causing damage to the soft parts (surround, spider, etc).
In a sealed box to spec you should be fine with 600rms, just make sure to watch your gains...
A subsonic filter simply protects the woofer by filtering out lower notes, below 20-25 hz usually, that your ear cant hear too well anyway...
the rl-i8 will handle 600wrms pretty easily, ported or sealed. in a ported app, you'll want the subsonic set jsut below port tuning to help prevent over excursion.
if you need 8s, the rl-i is your only choice from soundsplinter. if you want to move up to 12s, the rl-p is an awesome choice.
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
how do you set subsonics??, sorry I'm kinda a noob when it comes to enclosures, but I think I'm wither going to go with 2 8" Rli's or a single 12" rlp, thank you for the help
thanks for the link, also, I am thinking about getting a single 8 and putting it on a sundown sae1000D getting 600rms at 2ohms, then later I can add another rli and get the full 1000rms, do that sound like a good idea?? thank you
jester king
jester king
Michigan
mrray13
