SQL subwoofer reqs - looking for cone size, rms power, and model/brand suggestions
nefariouscaine
i'll be quick about this i guess...
looking at either going with 2 10's, a single 12 or a single 15
I mainly play hard, fast paced electronic music with very intense sub bass and driven bass lines with long note extensions - grime dubstep, breakcore, d'n'b, etc
At the moment i'll have around 1500w rms at 1ohm to play with
Might be getting custom subs built by a member here, might have a custom adire brahma built or go to stock specs on it (got a line on someone with new brahma motors), might buy something used or might go new. More then likely I'm gonna go custom to some extent or buy used.
budget is approx 200 give or take for the driver(s)
prolly gonna go ported and with trunk space should be able to do 2-4 cft - might go ported but db loss is a concern vs ported
i'm new to this so if there are flush threads i can read please point me in that direction - i've played with an Alpine Type X and loved it (wished i still had it), a RF t2, and currently use an RE SE-XXX
ask me any questions - leave me your suggestions and advice
if you're selling PM me offers
1 DC level 4xl. But you are gonna get the same advce as every other post about this. Pretty sure there are like 3-4 just on this first page of threads.
search button
Been searching and still an searching. I'll throw up my list of ones i'm thinking about now when i get home but i see many different things honestly. Alot of the same stuff most of the time.
Everyone so far thanks for in
ok
here is small list in no order what so ever
fi q / sundown z15 / still lookin at the type X and might have found one for decent $ local / adire brahma / id max / something custom with a 3hp motor / SSA ICON (or maybe a DCON...) / if i can find one used cheap enough maybe a Death Row
you listen to electronica and want to go ported? this makes me sad in the pants. If you want quick, tight bass i think you'd be better served with a sealed enclosure. Unless you plan to build a 4th order enclosure, sealed will give tighter, quicker bass. If you're looking for a 3-5dB gain at a particular frequency, then ported is what you'll want.
NO.
Why does this idea never die, even when proven wrong about 15 times a month?
NO.
um... quick tight bass... sure sounds great... electronica... not so much... you ever listen to grime or sub bass dubstep? not sure if you're thinking i'm listening to techno or house but this ain't your grand pappies 4/4 melodic trance
this stuff is sweeping notes, constant drives, crunchy reverbed reversing lfo's of a different order
download and burn - 16bit - The Milky Pie Mix - listen to it all the way through and thats a fabulous example of what I'll be playing
looking at the z15 after some other suggestions and possibility of getting 2 12" type R's cause they're so ****ed cheap around here used
for you OP you buy funky pup nao its all your logic and intelligence clear you to use
GTFO with those funky pups
at least bag me with something not so blatant gibberish and trolling
i'm gonna start suggesting those to all the homies i see in compton 2 or 3 times a week and see how much i can flood the ghetto with those dank awesome subs
I was merely pointing out his misconceptions on driver "speed" which isn't really a function of the enclosure, as much as it is with proper install/tuning/adjustments where necessary.
And to be honest, the driver it self is going to play a large roll in perceived "speed," and by that I mean transient response. For this, a driver with low inductance is necessary IMO. I'm sure some will disagree but that's my $.02 worth
28
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
Those pair of 12s with the right enclosure and tuned as well as powered properly should perform much better than the single 15, provided you have...
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
nefariouscaine
nefariouscaine
Los Angeles
Chrispy
