Gonna be rockin the old kicker amps in my ride //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gifSo far I completely agree with everything Helotaxi is saying.
You don't need expensive or esoteric equipment to compete. Amps aren't important as long as they have the power and features you need. Cables aren't important. Preamp voltage isn't important.
The #1 most important thing is installation and tuning (this includes sound deadening).
The speakers are the most important part of the physical system.....and even they don't need to be "expensive", just solid performers which can actually be very affordable. After speakers I would say the 2nd most important thing is adequate processing. You don't have to "over use" the processing, but you need to be able to properly equalize the system, time align if necessary (one seat judging) and it helps a ton if you have flexible crossovers.
You could very easily put together a competition worthy system with less than $2k in equipment.
when you set up your car for sq you set it so it doesnt have background noise and so that the speakers do not (or as close to it as possible) distort at all. when they do the majority of listening tests the vocals would be at about at a level slighty higher than a normal conversation. would be sweet if they added full spl points for this as well. thing i like about it is it puts installation back into the mixim curious to hear how loud is to loud for sq when u normally have ur car judged. like for me ad my setup i play at 56 out of 62 for my full tilt. what would be considered sq. is it like what u daily listening levels are. lets say 44 out of 62? im not sure if i wanna go sq, im pretty much happy with my amps. and well the positions in my car (kicks for mids and tweets) (doors for midbass) and i will def drop the cdt's and go diy with some hybrid audio's, seas, peerless, etc...) keep amps, sell sub, pickup some focal or id's and go ib / sealed.
but im not sure yet, i might continue my sql but step it up into 2000 watts on 6 8" re re's or 1 mx, 1 xxx, 2 12 se's, 1 15 aa havoc, 2 idmax's another q. etc...
with a sound quality cd like the iasca disc or http://www.crutchfieldadvisor.com/reviews/20030902/autosound_cds.htmlwow, i didn't expect such a conversation to spark with my original post, but I'm glad it did. My question wasn't particularly intended to suggest that I'm trying to build such a system, it was more out of curiosity. I'm far more interested in sq than spl and my set up is basic but sq oriented. I'm running two 10" idqs off of a xenon 600.1. I've got an 880 going to some entry level boston acoustic comps. I have already learned how important install is. I did a little custom work on my door panels so that I could move my mids out flush with the door panel, and I've at least doubled the mid bass. I don't ever plan on competing, but I am curious what kinds of things set a winning system apart from a clean sounding daily driver.
Um...not really. THD ratings are overrated, only because there is no set standard for measuring them. When you say quality crossovers it almost implies passive crossovers, which are not used very often. And there isn't a huge difference between RCAs, so long as they're shielded well and have good termination. And you don't need a HU with high voltage outputs. That's what the gain control is for on the amps.Amps with very low thd for a start...quality crossovers, quality rca's, HU's with high vlt rca's
