SQ 10" with 4" coil
ciaonzo
TheContinental
11,703
76
WI
10" driver from a $2000 Linn Majik home subwoofer. Same driver used in their Sekrit in wall system as well. Powerful high dollar musical gear.
Single 4ohm 4" coil. Driver is in great used condition, still very stiff. Tough rubber surround, stiff cone and lots of motor force, suspension is good for 2" of travel. I played with it for about a month on 800w, and it is incredible. Very efficient, very well behaved driver. Starts and stops on the proverbial dime. Drums are absolutely insane, ultra fast. Pitch definition is gorgeous. These are from the UK so there's not a ton of them out there. Here's a link to some more info. --> overture-audio.com | Linn MAJIK 126 10" Base Reinforcement Subwoofer
$300 shipped, CONUS.
CONUS only, please.
Nobody needs a 10" with a 4" voice coil that can throw 2" of excursion and absorb 1k? Hmm...
It's interesting but I think people aren't sure what to expect. I personally don't have an application for it but if I had a home stereo I would def try it out.
I'd bet you're right and I can't say I blame them. It's one of the reasons I went to lengths to describe it sonic signature. The reviews on the Majik were wonderful, not sure if folks understand the pedigree that Linn is associated with.
I feel like this would go great with my esx 120.4 and I'm really considering getting this.
Is that the one that can go true mono? That Zed would be awesome on this. You might even consider a vented alignment with that much power.
Have a means of pulling tsp's? No pun intended, I am currently in the market for a new toy (for the first time in years)
Hey, Phill! Real good to hear from you, it's been too long.
I don't have any measuring equipment these days so no real numbers, sorry to say.
I bought the parameter tester from Jeff on another forum. I'm going to try it tomorrow on those two TC9 15's that I bought. We'll see if it comes out somewhat reasonable. If it does I'd be willing to let you borrow it.
And ****... I was a bit interested in those LMS coils. It's probably a good thing though. I would've wanted to build motors from scratch for them.
Hey, I appreciate that.
I was considering doing the same for those LMS coils, a big quad stack with lots of copper. I just have too many irons in the fire.
Same here. I have a big underhung neo to build and a set of TC2+ steel that need to get machined so they can be my new little LMT motors.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
674
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
Okay i found one under b stock on alphards shop site but unable to actually place order grrr
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
