Spreadsheet Check Please
rollin_clean
Can someone check my spread sheet I am working on?
All you will need to do is run the numbers in my spread sheet then in one of yours to see if they are about the same. This one is for a ported box with a round port. All you need is the Sd, and Xmax of a sub, thickness of material (.75), and desired airspace (Vb). It should only take a minute. I will e-mail the spreadsheet to whoever will help.
approximate displacement (I found it somewhere and it was close to actual disp on a couple of speakers. . .possibly coincidence)
it also does port length, airspace, "golden rule" ~ box design
I'll e-mail you a copy so you can see what I am talking about.
rollin_clean
rollin_clean
prattville alabama
rollin_clean
vegang
vegang
