rollin_clean
Can someone check my spread sheet I am working on?
All you will need to do is run the numbers in my spread sheet then in one of yours to see if they are about the same. This one is for a ported box with a round port. All you need is the Sd, and Xmax of a sub, thickness of material (.75), and desired airspace (Vb). It should only take a minute. I will e-mail the spreadsheet to whoever will help.
