Split coil Fi? Sexiness!
Dis dat woofa....
Yep, isobaric involves two cones, very different than this idea. Isobaric did also cut down on THD *somewhat*, but the main advantage was in halving enclosure volume requirements, which use to be a bigger deal 10-15 years ago when subs were designed for higher efficiency which meant larger enclosure requirements.
How many cones are attached is kind of irrelevant. Tell me: does the radiating surface area change significantly? There lies your answer as to the semantics.
As Neil says, isobaric means two drivers push on the same shared surface area. It doesn't matter which way you mount the drivers, facing each-other or in the same direction, you wire them such that the force vectors are in phase. This is simply an isobaric motor, so its shaves a bit of moving mass compared to two isobaric speakers. I'm guessing they did this to increase BL and bypass some SPL contest rules?
so is this design only spl beneficial?
Well you get double the BL product, that's like going form 20Tm to 40, its a pretty big jump. But i'm not sure its going to increase your SPL numbers, at some point you just run into a displacement limit. The only thing more BL will do is get you there with less power, but you'll need more voltage because of higher impedance (even if Dcr is the same). More BL is never a bad thing, it will if nothing else will reduce the current load across the coils and protect the driver a little more - burps are pretty aggressive i hear.
tommyk90
THE WHOLE THING!!!
tommyk90
Chicago Heights, IL
corrie32
