SPL Ranger version 2.0
bunkerking09
Current Status: Win
After blowing my first sub, i decided to change things up a bit, so I hope you guys enjoy.
Subs should be reconed within the next day or two, so maybe some some vids by the weekend, but i won't be playing them to hard. Hope you enjoy...
DD 9510(2)
DD Z1
Lots of 2/0 welding cable
Ohio Generator coming in like a week
Optima YT(2)
The baskets...
the recones
So i thought about how to make a tunable port and decided that PVC pipe would be a lot cheaper and easier to work with. So the black thing is like a grate, i dremeled out the parts interfering with the air movement and i'm using this to screw to the box, i connect that to a piece that connects two 6" pieces, and vuola you have a changeable port.
Got port???
The box is 2.6 net tuned to 45hz, triple baffled on top, i'll get more pics of the box later. Its subs up ports on bottom to drivers side. Braced the **** out of it, this thing is solid.
amp will be mounted on the front of the box in an amp rack so its not so thief friendly.
WIll update with more pics later, trying to hit the 150 mark. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
maybe just a little bigger on the box.
interesting to see what numbers you put up and how it sounds //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I mean if your wanting to go cheap and you like making things i guess you could always make your own , is all you really need is a DMM a...
Excellent place to get a Tuned enclosure with everything Precut and ready to put together with a Diagram of each sheet Marked. $190 bucks. All you...
15
Highest my car has done is a 156. I have 1200w on highs and recently swapped the mids to pro audio mids. This was a challenge as I find many of...
bunkerking09
Current Status: Win
bunkerking09
Kansas City, MO
bunkerking09
audiobaun
    May 19, 2024
    May 19, 2024
