spider spacers???
It happens
4
MN
ok so i have been wondering what is the puerpose of them? i know you can get spiders that are not stackable so that would be a reson... but other than that is there a reason that i dont know thanks a head of time for everyones help
There's only so many you can stack at a go. Then you need to space them and do another stack. I've used some very soft suspensions on some very tight gaps and haven't had coils fail from rocking so while it sounds good in theory I don't think it's crucial, particularly considering how wide most of the Chinese sub's gaps are. The only reason I'd go out of my way to use them (apart from cosmetics) would be if I needed stiffer than I could get with 1 stack.
thank you i have been having issues with coil rock and i be leave i need to go the rout of a spacer
It happens
It happens
MN
It happens
