vibe v12 air 1600watts subs
monster666
kent
i have two vibe v 12 dual 2ohm subs and i cannot deside how to wire them up i have a lanzar 1000watt 2 ch amp i was going to wire them at 2ohm at 500 watts each channal but thats just using one voice coil or i could wire them to 4 ohms and bridge the amp and use the hole 1000 watts can someone help me and show a diagram thanks
if it was my gear i would run the amp bridged at 2ohms- set each sub up in series then run them parallel to the amp.
this may blow your amp as it rated at 4 ohms bridged miminum, but then you could buy a better amp that would fit your subs better.
monster666
monster666
kent
SMS
