Speakers seem to "dim" or go "flat"?
warr40
Hello i have some CDT comps on a sundown 100.2
and if i turn the volume up to a decent level, the speakers seam to "dim" or go "flat" not really sure on how to explain it.
What should i start checking?
could it be a voltage drop say when the bass kicks in?
Speaker wire gauge?
Gains?
Please help?
You are clipping most likely. You've got the gain turned up too high on the amplifier, and/or too much signal coming from the HU/crossover or whatever - to the amp.
Hard to see without an oscilloscope, but try just turning the amp gain knob down a quarter turn.
depending on the crossover, if it gets too much heat build up it may shut the tweeter off. diamonds are notorious for it. the protections mechanism melts when heated up, destroys the connection to the tweeter and when it cools, it reforms and the connection is there. this is most likely the case.
that seems highly possible, what do recomend i should do
set up the gain properly. find out where your deck clips at, if you have a processor, find out where it clips at too. then if you still have problems, maybe some gear change is in your future.
im new to this should i use the multimeter method to set up my gains?
and what does clipping sound like?
i dont have enough expiernce to do it by ear really.
ok just installed this set in my new mercades with the tweeter close to the woofer like CDT suggests and still have the same problem
You may be running into power compression. Does it kinda stop getting louder as you turn the dial near that point? If so that's the problem. They dynamic range of the recording stops mattering because even though your amp is adding power to the speakers, they simply don't have the ability to intensify that much.
to me it seems like your sending a pretty clipped signal to your comps. my buddy had the same problem in his silverado with some ARC Audio FD6.5 comps(and some MB quarts before that). at mid volume they sounded great but once he turned it up the would get loud but then a few seconds in or if some very high notes hit the tweeters they would attenuate(shut down) but if you turned the volume down they would come back on.so i added a line driver to compensate for his low volt rca signal and turned his gain down to about 1/4 from 0. and it never happened again and his tweets would be loud n crisp at higher volumes
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
300
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
227
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
389
warr40
warr40
wantagh ny
Ineed$
Decebal
    Jun 10, 2024
